Importing STL file results in changing the model to a larger scale
Whenever I import an STL file the scale of the model is increased in size by a rather large amount.  It's not a matter of the program using different units of measurement as the original STL is in millimeters and Fusion imports the model in millimeters also.  The size difference is something in the order of the original model being something like 10 mm and the import ending up being something like 200 mm.  Any ideas?
Thanks in advance.
laughingcreek
Honestly, that still sounds like a units issue.  What program created the stl?  Can you attach it here?
