CANNOT APPLY PROPER BALLOONS TO DRAWING VIEW IF COMPONENT EDGE IS NOT TO OUTSIDE
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am running into an issue where if i create an assembly BOM table with parts that are wholly within the surrounding within the context of another part (imagine a plate with another part that rims its edge so that the first part covers the edge of the plate) when you go to create the table, it does not acknowledge the plate as a part. It will create a single part BOM table that only calls out the part on the perimeter. It does not allow me to add any other balloons with different numbers. I tried to hack in a balloon with a "2" (create on and then use the move command to disassociate it from the original target) but that does not work as it is tied to the first (if i change one, it changes both). not sure what the remedy is. I would appreciate some help.
