Making drawings - Parts are enabled to be displayed but not showing in drawing
crchisholm
crchisholm
I was going along just fine with this design and everything was showing perfectly.  I tried to isolate one body to print and somehow now I can not see MOST of the bodies in this design.  I don't know what I turned off, but I can't get it back on.  There are a lot of parts, but most are not visible even though visibility is turned on.
Any Help??
Charlie C
TheCADWhisperer
Are there any issues indicated in your timeline?
Can you File>Export and then Attach the *.f3d file here that exhibits this behavior?
HughesTooling
You need to expand the Body folders and make sure any bodies in the folder are set to visible. In your screenshot all the body folders are collapsed I can't tell if the bodies within the folder are hidden.
Mark
Mark Hughes
Owner, Hughes Tooling
crchisholm
I got frustrated and created another drawing and everything works on that one.  I tried to delete the one I had the problem with and now two days later, it's still there and I still have a spinning donut.  I created another post regarding that.
