Ever since the last update, I can no longer use the align command for linked components. It only works when aligning bodies which if you have a component with multiple bodies and joints it messes that all up.
Whats the deal?
Whats the deal?
seems to work for me. You'll need to share your design and a video to get more help.
I cannot share the model. I can replicate what you did by making basic shapes.
After playing around this is what I found out.
-I cant align components that come from an outside source (McMaster-Carr, etc). If I break the link I can then move just the bodies.
This was not a problem before the last update.
I am using a Mac if it matters
If you can reproduce this on a simpler model, and can share that, it would be helpful. I'm not sure what your workflow is. If you use the "Insert from McMaster-Carr" command, that creates a local component. I just tried downloading a model from them, and inserting it, and that seems to work as well.
