Not sure how to unfold this sheet metal bend so I can create a drawing on it and modify it. I assume it's an easy fix but I'm spinning my wheels!:
Solved by g-andresen. Go to Solution.
you've got to have a flat spot somewhere. here's one approach-
https://knowledge.autodesk.com/community/screencast/ff320183-6750-41d3-97a8-713a57122fce
try this:
1. extrusion for stationary entity
2. Unfold
günther
Thank You Guenther, that worked well and thank you Alex, I'll try that next time.
Yeah... Fusion has got to have at least one tiny flat face (everything else is a bend) to reference and unfold everything else from.
thank you so much! it took me so long to figure out what to google to get past this but you solved the problem perfectly!
