Can't split body: No intersection between target(s) and split tool.
4 REPLIES 4
grimmdp
238 Views, 4 Replies
Hello, I am having problems splitting a body and hoping there is a solution. I created a toroidal ring and lofted a connector into it, and at the time, didn't realize I had allowed it to join. Unfortunately now, I can't split it using the toroidal surface, I keep getting the mentioned error even though the connector was lofted into the center of the ring. Hoping there is a way to fix this other than re-creating it.
Thanks, Dean
4 REPLIES 4
aliobidi
in reply to: grimmdp
Hi ,
first of all please capture design history when you work .. this allows you to edit your project with the timeline
see This screencast
your file below
grimmdp
@aliobidi thanks so much! Turning on timeline now, thanks.
davebYYPCU
Can be done without the timeline but result may be unexpected.
Might help....
aliobidi
Do not forget to mark the Forum post, that solved your question, by selecting the "Accept Solution" icon. This closes the question, makes the solution available to others with similar questions and acknowledges the solution as helpful.
