Can't select the entire projected geometry.
reik_001
reik_001
Hello.
Have a problem when I try to select all sketch geometries.
I project geometry from 3D model to sketch that include some small parts, and when I try to select all parts, small ones are didn't selected.
"Select Through" is off.
What's the problem?
And another one question, when I choose all geometries manually, then click "Break Link" and try to rotate, there is nothing happens, why?
masa.minohara
Hi @reik_001,
Thank you for posting your question! Could you try turning on "Select Through" option? Or try double clicking a line to select all the connected entities?
Regarding rotating the sketch, how did you try to rotate it? Did you use Move command? Would you be able to share a public link to the design or attach the design here?
Masanobu Minohara
Product Support Specialist
Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
reik_001
Here is sketch geometry from model in attachment.
There is no changes when I turn on "Select Through" option. Double click on it select area only with few lines.
Yes, I try to rotate sketch by selecting all lines, then press "move", select pivot point, and write an angle.
Thanx for reply.
masa.minohara
Thank you for attaching the design! It looks like this is a known issue, and to work around this, you need to zoom in and select those small pieces of entities. I am sorry for the inconvenience.
Regarding rotating the sketch by using Move command, did you click on "Done" button after setting Pivot?
Masanobu Minohara
reik_001
Now rotation is complete, thank you for advise. For the first look this green check mark looks like seting pivot point is done )
But with selection of sketch geometries looks like a lot of unnecessary work... Hope it will fix in future.
I'm very new at fusion.  seem like you can't select Bodies AND components at the same time.  I still don't understand the concept of bodies vs components.  I am drawing shower doors.  As i create an assembly, i want to "Group" it, lock it together.  I.E a piece of glass with roller bracket attached and a trim piece across the bottom.  If the glass is a Body and added parts are components, when i move the assembly, one or the other doesn't move, with select thru checked. so, i draw everything as a component and change all bodies to components and don't have a problem except for the quantity of small parts to be grouped.
If anyone would like to comment, i would be interested !
Norm
