Can't open files anymore after the update
chrissem
chrissem
Hey, I last used fusion on Monday and now I can't open the file anymore. I think it's because of the Fusion update I did this morning. The file keeps loading in the file manager and when I'll open it Fusion will crash.
chrissem
I was able to fix the problem by going into ofline mode. then I opend the document and switched to online and saved it. Now it's working...hopefully
Hi chrissem,
                   Try opening the file through A360. I hope this might work and solve your problem.t.png
chrissem
THX, but I tried that too and it didn't work...same error message
andreotti60
I'm having the exact same issue.  Many hours of work down the drain.
saketsatta
I'm sorry to hear that you are having a problem opening your files. Could you please upload your log files here or send them directly to saket dot satta at autodesk dot com so we can analyze the issue and find a solution?
Saket Satta
Fusion 360 development
