Can't open a project
Hi
I am in a jam. I modeled my whole project in Fusion and now after yesterdays update I cant open any large projects. The projects are quite large. The wheel spins for like 30 seconds and then the crash panel comes up. I am really stressed. Fusion has been crashing alot, either with loading, saving files or even trying to make drawings from one of the components.  Please help me!!!!!
http://a360.co/2eOouec
I have i5 2500K
8gb ram
windows 7 64 bit is this helps
My friend says it took over 60 seconds to load on his machine
masa.minohara
Hi @Anonymous,
I am very sorry to hear about the issue. I downloaded your file and uploaded it to my project, and as you reported, Fusion crashes when I try to open it. I've found that the crash report is associated with a known issue (UP-32082) and the development team is working on this right now. I'll let you know as soon as they fix the issue or find a workaround.
I am sorry for the inconvenience.
Masanobu Minohara
Product Support Specialist
Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
masa.minohara
Hi @Anonymous,
Thank you for waiting. I just received the fixed file from the development team. I was able to open the file without Fusion crashing.
http://a360.co/2fGLWeS
Please download the file from the link above and let me know if this works for you.
Masanobu Minohara
Hi  masa.minohara
Thank you very much. I am going to see if it works. If not I will revise my work. I got an extention for this work. Thank you the guys.
After latest update this particular file doesnt hang, it does take over two minutes to load. After not working on the file for two days, gave me time to think, so I used old version of the original file and reiterated. I will upload to the gallery when this project is finished. Thank you for your help.
I am a bit sad that the drawings part of the program broke, it tells me to reinstall. I dont dig this idea. I will there was an install file. Streaming downloads is nice for some but not nice for others. I will have to repair Fusion after my hand in
Thanks Kirk
brianrepp
Hi @Anonymous - for the drawings issue, are you on the current version of Fusion?  If not (or perhaps if so), have you tried this workaround?
