milling top and bottom
Hi all,
Iv'e designed a dish that will require top milling, a flip then bottom milling. When planning the stages is it recommended to create one setup with both sides or two setups, one for each side?
thanks
innovatenate
Autodesk Support
Autodesk Support
Welcome to the Fusion Community!
I would recommend doing a Setup for each side. I also want to note that we have a dedicate CAM board where you can discuss strategy with other CAM users.
I hope that helps. Let me know if you have any questions.
Nathan Chandler
Principal Specialist
