Hi. I've been trying to use the offset tool to simply draw an outline of an imported SVG shape. For some reason, I can't offset the shape to go outwards, it only works inwards.
I get this error when attempting to offset the shape outwards: "The sketch offset created no geometry. Modify the offset dimension or verify the changes are correct."
I have attached a video of the error and the file down below. Any help or advice would be greatly appreciated.
Solved by g-andresen. Go to Solution.
Thank you Gunther. That's so small I wouldn't have seen it in a thousand years.
Hi! Another approach to try is to leverage Offset Surface. You may extrude the profile as a surface body. Then create an offset surface of the extruded surface. Lastly, project the edge from the offset surface to the sketch.
Many thanks!
