Can't move assembly
Can't move assembly
Can't move assembly
I'm trying to move an assembly as shows in the video.  It just won't move.  What could be the possible reasons?  One of the parts is a "ground" object, I'm not sure if that will affect things?  The whole assembly has joints in it, but they are linking components within the assembly, not outside of it.
I'm a bit stumped to be honest.
Any advice greatly appreciated.... Rob
Just adding further info to this. I've gone and tried to move just one component within the assembly to see if that helps, but it won't let me select the component to move it.
I can select the component, press M and then it deslects and shows the move dialog.  When I then try and select that component, I can't.
michallach81
All because it grounded, suppress that "ground" in a timeline and see if now "move" will work.
Michał Lach
Designer
co-author
projektowanieproduktow.wordpress.com
That did it thank you. As a note I couldn't suppress the ground in the timeline, I had to "unground" it by right clicking on it, moving it, then grounding it again.
I appreciate your help. Thanks again!
