Assembly problem
Assembly problem
jakob
Assembly problem
jakob
A try to assembly a engine in f360 but its very hard.
I am used to Pro/e  and SolidWorks mates and F360 makes it hard.
Are there some way to add mates more like SolidWorks?
I cant understand why this not work, try to add the rod connection to the crankshaft.
https://grabcad.com/questions/tutorial-how-to-make-engine-part-22
I try to do this tutorials. Please check the video.
michallach81
Joints are slightly more complex then mates but allow us to use single joint instead of multiple mates, like on image below:
You should watch some tutorials about assemblies in Fusion
Michał
Michał Lach
Designer
co-author
projektowanieproduktow.wordpress.com
jakob
Thx you, problem solved I has chosen the wrong join type. It works!
