Can't get rid of material in an imported model
aleksei_ovsienko
aleksei_ovsienko
This has been mildly annoying for a while.
I have a bunch of models I imported from a different CAD. And when I go to change the material there's always one material that can't be deleted from the model. You just can't unassign and delete it. There's the default material from Fusion that can't be deleted. And there's this other one.
It's not a big deal. I can assign a different material anyways. It's an eyesore, that's all. Can this be helped?
https://a360.co/3J10qp7
dsouzasujay
Hi @aleksei_ovsienko ,
  1. Go-to "Physical Material'
  2. Right click on the material and select 'Unassign & Delete'
Also, If there is any appearances applied, You can select all the local bodies/components, Right click select
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
aleksei_ovsienko
Well it's the other way around that I want it. I want to keep the pine material and get rid of all the others. And that's what it wouldn't let me do.
dsouzasujay
We cannot leave the default Physical material empty.
It's necessary to assign a default material when creating new entities (Ex: Solid bodies).
I recommend changing the material in the preferences, and then we should be able to delete other physical materials.
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
