can't get circular pattern to work
evanp4509U4JZ
Message 1 of 11
evanp4509U4JZ
I'm trying to simulate a machining pattern on a part for representation purposes. The idea is the swirl that looks like jeweling. When I try it previews the way I want it but when I hit "OK" it turns into a partial pattern with voids.
Model example is attached with timeline.
Thanks in advance.
Replies (10)
Message 2 of 11
aliobidi
Hi ,
do you have a picture of what want to do ? if yes attach it
Message 3 of 11
dsouzasujay
Hi @evanp4509U4JZ
Can you please provide more details?
May be an explanation through video or through an image?
Bases on my understanding, are you looking something like this?
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
Message 4 of 11
evanp4509U4JZ
Yes, something like that but without all the discontinuities. If you edit the pattern in the timeline and set the instances to 72 it previews it almost exactly as I want it. As soon as you hit "OK" it turns into the garbage it gave me and you in the example.
Unless it is my computer and on your end there aren't missing segments and the occasional straight line.
Message 5 of 11
evanp4509U4JZ
No photo. If you edit the pattern in the file with 72 instances it previews as I would like it. Once you hit "OK" it turns to junk like the example in the file.
Message 6 of 11
JamieGilchrist
Hi @evanp4509U4JZ ,
What's your end goal?  are you looking to actually produce something?  render something?  what's your target?
hope this helps,
Jamie Gilchrist
Senior Principal Experience Designer
Message 7 of 11
KristianLaholm
Is the image below the design intent?
Extrude 2 must be the full circle, the partial extrude you hade did leave some strange geometry due to the angle of the body, and that made the circular pattern fail.
Changed Move2 from Free Move to Rotate (makes the feature parametric and easier to change)
Message 8 of 11
evanp4509U4JZ
Purely to show the end result of the machining to present the product to the board. Is that renderring? I think it's renderring.
Message 9 of 11
evanp4509U4JZ
Awesome. Yes, exactly. Thank you very much.
How did you come to that conclusion? I zoomed in to look at the geometry created by the cut/combine and didn't see anything so I charged ahead to the patterning.
Thanks again.
Message 10 of 11
JamieGilchrist
hope this helps,
Jamie Gilchrist
Message 11 of 11
evanp4509U4JZ
Similar. The result in post 7 is what I was trying to create in this instance.
Thank you.
