Fusion 360 DB error // no such table main. Technologies
thomas-rappel
thomas-rappel
I uninstalled with the cleaner and reinstalled on 4/4/22 via my account. I can't find the file user/ thomas / app data etc. So I can't delete them. The error still exists
RajkumarIlanchelian
@thomas-rappel Can you post an image of the path you are accessing to get to this folder please?
C:\Users\{YourUername}\AppData\Local\Autodesk\Autodesk Fusion 360\Electron\{YourUId}\lbr\libraries.db
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
thomas-rappel
here the path :
RajkumarIlanchelian
Autodesk Fusion
Join Fusion Insider
RajkumarIlanchelian
1. launch File explorer
2. Type in %Appdata%
3. On the folder structure that comes up, it will take you to Appdata-Roaming
4. Go back one level to Appdata
5. Here you will see the Local folder
and the rest you can navigate per the below:
Autodesk Fusion
Join Fusion Insider
thomas-rappel
Hello, Rajkumar you are graet. it is working now. Thank you.
