Can't Finish Form: Conversion Error
kodagrux
kodagrux
So I've created 4 different faces in the Model environment that I've merged together, keeping the creases sharp. When I try to finish the model (by pressing "Finish Form") I get an error saying "Error: Conversion error for: Hull The operation failed due to a G1 discontinuity in a surface. Try adjusting the values or changing the input geometry."
When I go in and edit the form i can see that there is something strange going on in the top left/right faces of the back of the boat, which I guess is causing the problem:
However I have no idea how to fix this. I've tried finding a solution but without any success so I'm hoping someone can help me out! Hopefully i've come to the right place for help.
I've attatched a the f3d-file. Thank you so much!
jeff_strater
Hi @kodagrux, see the screencast below.  The problem is exactly where you described it to be.  The solution is pretty easy - Weld Vertices to put those mis-matched vertices back together.
It looks like you have a lot of duplicate bodies in your model.  Are those intentional?  It doesn't affect the model at all, just curious.
screencast:
Jeff Strater
Engineering Director
kodagrux
Wow. Thank you sooo much! Those extra vertices came from when I merged the edges from the 4 different faces (top, side, bottom, back). Haha those extra bodies are just quick backups that i just hid while i was working; was trying out some different things with the extra bodies to try to solve the problem 🙂 Again, thank you very much Jeff!
