- Mute
- Permalink
- Report
So I've created 4 different faces in the Model environment that I've merged together, keeping the creases sharp. When I try to finish the model (by pressing "Finish Form") I get an error saying "Error: Conversion error for: Hull The operation failed due to a G1 discontinuity in a surface. Try adjusting the values or changing the input geometry."
When I go in and edit the form i can see that there is something strange going on in the top left/right faces of the back of the boat, which I guess is causing the problem:
However I have no idea how to fix this. I've tried finding a solution but without any success so I'm hoping someone can help me out! Hopefully i've come to the right place for help.
I've attatched a the f3d-file. Thank you so much!
