Can't fillet a corner
JetForMe
JetForMe
I'm trying to fillet a corner in a sketch of a rectangle. The outer rectangle worked fine. The inner one, two of the corners went fine, but the lower-right had some issues, but finally worked. The lower-left, however, I just can't make it work. See the following screen recording (not an autodesk screencast).
 http://cl.ly/3X2X1v0w0O2N
MacBook Pro, PCNC1100 Series 3, Slant-PRO 15L Lathe, Custom AvidCNC-based 4x9' CNC Router w/24k 4.5 kW HSD Spindle & Teknic SDSK Servos
jiang_peng
I am sorry that you having that problem. Could you please share the file to me? My email: jiang.peng@autodesk.com
As a workaround, please refer to:
http://forums.autodesk.com/t5/design-validate-document/sketch-fillet-on-acute-angles-flips-after-cli...
Sorry for the inconvenience!
jiang_peng
I just tested on development build. The behavior is improved but still has some issues. I logged a bug(FUS-25637) to track the issue
thanks
