can't delete part of my model
Message 1 of 13
Hi can anyone help with this? i try to delete a random face on my model and it's no go. select and hit DEL and i get an error message "selected part is read only". i use Modify...Delete, the delete dialog box appears and when i go to select something it won't select. here's a screenshot:
Replies (12)
Message 2 of 13
Hi!
unfortunately you cannot simply delete that part.
A simple way to do it is to select that face and click on extrude or simply type "E".
Then drag the blue arrow downward and you will delete the part.
Hope it was useful
Giuseppe
Message 3 of 13
thanx for the reply, but that doesn't seem to work either. look
Message 4 of 13
ok YES!
because in the extrude panel that you have on the right of your screen you have selected the option "join".
instead you have to select the option "cut"
Message 5 of 13
thank you again but still no go...
Message 6 of 13
.... it is really strange..
I will try to find out what happens
Message 7 of 13
josef.kucera
Hi @Anonymous
I can look at your design if you share it with me. You can send a file to via PM or to my email: josef dot kucera at autodesk dot com...
Josef
Josef Kucera
Fusion QA
Message 8 of 13
hmmm... all my files are saved on my folder in the data panel but i don't know how to upload them here. where on my disk is the data panel?
Message 9 of 13
josef.kucera
Message 10 of 13
Message 11 of 13
josef.kucera
Hi @Anonymous
thanks for the design.
I am not sure what is your intention with the design but when I upload the f3z file I see three designs: "steadycamLower" inserted/linked into "platform" and "platform" inserted into "untitled" design.
From the video you attached is not obvious which design are you editing but I made two screencasts videos with different approaches of removing an unwanted part from model:
1) first approach is opening of a referenced design, save and update linked file in the assembly:
2) second would be in-place edit but referenced design (link) has to be broken...
Josef Kucera
Fusion QA
Message 12 of 13
Ok so it appears that the problem occurs because i'm not opening my files for editing, i'm creating a new design every time and dragging an existing model onto the new canvas from the data panel.
thanx so much and thanx giodesiato i was just doin it wrong.
mike
Message 13 of 13
josef.kucera
Actually it's not a problem it's as designed.
Inserting design into another design produce a new assembly with referenced/linked design which could be edited/updated way I showed in the first video...
Josef
Josef Kucera
Fusion QA
