Can't delete model from Fusion account
crullier
Message 1 of 18
crullier
Fusion keep saying it being referenced somewhere, but it is not.
has anyone run into this?
I have verified its not used in anything.
Replies (17)
Message 2 of 18
maker9876
I've heard that it can be because one of the earlier saved VERSIONS of the document might be referenced somewhere.
My fix is to create a folder called TRASH and just move unwanted - yet undeleteable - stuff to there.
Message 3 of 18
crullier
Thought of that, but not the solution I am after.
Message 4 of 18
maker9876
It might be the answer that you are stuck with. 😄
Message 5 of 18
seriously lol.
Message 6 of 18
daniel_lyall
Try to do it in you A360 account, open the file that wont delete then have a look at used in
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Message 7 of 18
crullier
I just wanted to say that such particular model can not be deleted despite it not being used anywhere.
Message 8 of 18
daniel_lyall
Does it have one component in it or many
Daniel Lyall
The Big Boss
Mach3 User
Message 9 of 18
SaeedHamza
Has the model been inserted into other designs before?
Regards
Saeed
Saeed Hamza
Message 10 of 18
Yes, but it was deleted from that model.
Message 11 of 18
SaeedHamza
Hi @Anonymous,
Are you working with @crullier on the same model?
Regards
Saeed
Saeed Hamza
Message 12 of 18
crullier
I'm at work at sometime the account get mixed up. So the a swer you are
looking for is, no, no one is collaborating
Message 13 of 18
SaeedHamza
Good to know it's the same person lol
Anyway, it might be the link between the project you're trying to delete and the project it was inserted into what is causing this problem so please give this a try ...
Go and export the project it was inserted into, and save it to you're computer, then delete it from your data panel, after that go ahead and try deleting the project that you couldn't delete
The whole idea here is to remove anything that has a link with that project that you want to delete, and then try deleting it again
If that didn't work, the project it was inserted into can be uploaded again from your computer since it was exported, so it's safe to delete it from your data panel to try the above
Please keep me updated
Regards
Saeed
Saeed Hamza
Message 14 of 18
crullier
good idea, let me try that.
Message 15 of 18
crullier
so I ran into a small challenge. Apparently we cannot download assemblies for archival?
Message 16 of 18
daniel_lyall
Not from the data panel you should be able to do it from your A360 account just open that model and click on the download icon in the top right corner and select the format for it to be downloaded as.
Daniel Lyall
The Big Boss
Mach3 User
Message 17 of 18
crullier
What happens when you promote an older version of a design. Does it
override the current most recent?
I found that the part I can't delete is in an older version. At least
according to A360.
I wonder if there is a way to delete previous versions of a design.
Message 18 of 18
daniel_lyall
override the current most recent?  Yes it does
according to A360. That will be correct
I wonder if there is a way to delete previous versions of a design. Not sure if you can I know you can open them as read only and save it out or save as
Daniel Lyall
The Big Boss
Mach3 User
