Can't delete file because previous version is referenced to another file
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm going to explain it with an example to see if it's understood.
I have the file "A" to which I referenced files "1," "2," and "3" in previous versions. Now, the file "A" in its latest version no longer has the history enabled and does not have any body, component, etc., nor anything referenced within it.
I understand that I can't delete files "1," "2," and "3" because they are in a previous version of file "A." The problem is that I can't delete file "A" in any way either.
Is there a way to delete all the old versions of "file A" to eliminate the "version history" and thus never have had references?
Or is there any trick or method to solve it?
I can't do it from Fusion or A360. The problem is that file "A" has more than 100 versions, and while I could find the versions where the references are, it doesn't help me at all.
If I wanted to delete the links in old versions, I couldn't save them as "old versions," but as another file or as the "most recent version," but it's a loop without a solution.
