Can't create a drawing of a specific design
laurent.vidonne
Message 1 of 10
laurent.vidonne
I'm having trouble with a design, from which I can't create a drawing : when I place the first view of the model, I get a red square rather than the view. Other designs don't seem to have the same problem. I've tried to 'compute all', save, close and reopen the design, same trouble.
Here's a link to the design : http://a360.co/2uOKMpT
Any help is appreciated, thanks in advance
Laurent
Replies (9)
Message 2 of 10
patilsm
Hi Laurent,
Thanks for your details provided for drawing issue.
I have downloaded your part and try to create the drawing for same.
but same issue I have also faced while drawing creation.
So I have reported this to our development team to look at this issue.
Sagar
Sagar Patil
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 3 of 10
laurent.vidonne
Thank you for your help, looking forward for a solution !
Laurent
Message 4 of 10
patilsm
Hi @laurent.vidonne,
Good News,
This fix is available for you in next release.
Sagar
Sagar Patil
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 5 of 10
laurent.vidonne
Thank you for your reply. I've just tried drawing from the same design, same issue.
I've had trouble with automatic updates of Fusion 360, so I'm not sure that I'm running the latest version : current version for me as of today is 2.0.3257. Is that OK ?
If not, what is the latest version number issued ?
Laurent
Message 6 of 10
TrippyLighting
That is the current version.
What @patilsm did not tell you is that often these fixes will fix things for A new design, but the old design still exhibits the problem.
What you could try is to run a "Modify->Compute all" and see if that helps.
Message 7 of 10
TrippyLighting
I downloaded and your design and created a drawing from it. I don't see this issue.
Edit: Sorry, I do see this issue. The preview is OK but when you click OK it's  still replaced with the same red square.
@patilsm please provide the FUS number for this bug.
Message 8 of 10
laurent.vidonne
and thank you for taking the time to look into this issue.
Yes, exactly same thing here, so it does not seem to be specific to my set-up. I also tried to run "compute all" as you suggested, and still no luck...
Other designs don't have the same issue, so I guess there is something specifically wrong with this one. Could be some sort of corruption in the file, as I don't think that I'm doing very fancy things there. Could re-create it from scratch, and try drawing from it at several points in the design process to try and identify what breaks it, but frankly I'd rather spend time on completing this work...
Ideas ?
Laurent
Message 9 of 10
patilsm
Hi @TrippyLighting@laurent.vidonne,
This issue gets fixed, Refer Ticket ID FUS-34635 just for your reference.
I have tested this issue internally where it working fine for drawing creation.
This Fix will available you on 26-Sep release.sorry for it not mentioned in my last post.
Sorry for inconvenience you faced.
Sagar
Sagar Patil
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 10 of 10
laurent.vidonne
Hello Sagar,
Thank you for your reply, I'll just wait for this release and confirm it's also OK on my side.
Best regards,
Laurent
