Can't add a kink to sheet metal cross section
kris.jackson92
Observer Observer
kris.jackson92
Observer
Observer
I'm trying to model a cross section for a car chassis in sheet metal, it needs to have a lip/brim on the edge of it to attach to the car, but it also needs to have a kink part way down the length of it.
I can't seem to get these 2 requirements to work together. I've tried sketching the length of the section with the kink and then adding a flange but I can't find a way to add the lip afterwards. I've tried splitting it in to 2 parts, sketching the cross section and then joining the 2 lengths but I can't build the kink in, and then finally tried sketching the cross section, extruding the full length of the part and adding a bend but there are interjection and interfering errors.
I'm by no means a 3d modeller but thought it would be easier to model this than it is turning out to be
jhackney1972
I used your cross-section but the length is just arbitrary.  The "kink" angle is approximately to what you modeled, again I just wanted to see if this suits your needs.  Of course this shape will not unfold, you did not mention that as a requirement.  If it suits and you need help interpreting the timeline, let me know.  Model is attached.
John Hackney, Retired
Bunga777
I saw this using a sheet metal miter treatment.
I am not sure if this can actually be fabricated in sheet metal.
First of all, the sheet metal does not seem to be right-angled in this first sketch in the figure below, so this will not allow the sheet metal to move properly.
I will review the sketch carefully.
Horizontal as shown here.
Sketch the bends to be mitered on the end faces.
After that, select profiles and edges.
The miter treatment gap of the sheet metal rule has been reduced.
The final shape is shown here.
Video here.
https://knowledge.autodesk.com/community/screencast/5b3255cf-0af1-4d36-8c03-08cba2c6ebd0
I have attached the data for your reference.
stiller.design
you won't be able to unfold / fabricate this kink. its self intersecting (inner side)
Bunga777
Hi, @stiller.design
I know this cannot be manufactured with regular sheet metal, which is why I wrote that in the first place.
I just presented it as a methodology for modeling with sheet metal, and if you really want to manufacture this part, it is the manufacturer, not this forum, that you are discussing this project with.
stiller.design
yeah, I thought so....you were just trying to help with the 3d modeling
