Can I use linear materials for non-linear static simulation?
I am on a non-linear simulation for my design. Is it possible to run some portion of materials that are linear, such as acrylic, and one component is non-linear (rubber)? I got the following message and my simulation can't be solved...
Warning: One or more of the physical materials do not contain nonlinear properties. The material may not behave as expected in the current analysis type. Nonlinear properties are recommended.
Click here to select 'Study Materials' to set a material.
John_Holtz
Autodesk Support
Autodesk Support
Yes. You can use a linear material in a nonlinear analysis.
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided, indicate the version of Inventor Nastran you are using.
If the issue is related to a model, attach the model! See What files to provide when the model is needed.
