- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I know that I can manually add User Parameters and give them names. It's an incredibly powerful feature that I use all the time, because changing any User Parameter causes all sketches and objects and components that are defined by those parameters automatically get updated appropriately.
But suppose that I have added a dimension on a sketch. Is there any way that I can then give that dimension a name, so that effectively it becomes a User Parameter? I know that I could just manually copy the value of that dimension and go to the User Parameters dialog and add it as a new named parameter, but that wouldn't actually ASSOCIATE that parameter name with the sketch measurement. If something changes on my sketch that causes that dimension to change the User Parameter that I created from it would NOT automatically get updated since it really has no association with the sketch diameter.
So, IS THERE A WAY to have a measured dimension on a sketch and THEN associated a User Parameter with that measurement?
