Can Fusion 360 quadrify export as MoI?
I include an example to clarify it. The idea is to have a regular mesh structure that allows bending and deforming in Max without triangles artifacts, to some extend.   I want to avoid large ngons or finely divided triangles with not quad pacing. Triangles are OK as long they have inserted in quads. And if not, what is the alternative in Fusion 360?
cekuhnen
I think what you are looking for is a retopo of the mesh into quads right?
If yes Fusion cannot not - this is a tricky task you are looking for.
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
Well, this is specifically what I'm asking. It is not a manual retopo but an automatic export setting where you simply set avoid ngons and divide flat and curved areas in squares of certain size. I was wondering if Fusion 360 has similar settings or is the typical mess of elongated triangles and ngons from cad programs that can not be deformed or subdivided in external programs as Max:
TrippyLighting
No, that is not possible with Fusion 360.
Ok, thanks.
I think that Fusion 360 really needs something like this to connect it better with programs as Max or Maya. The models in this way are easier to edit and don't become the typical uneditable mess of Cad models.
cekuhnen
I brought this up to AD that Fusion needs a better mesh exporter for deformation and rendering but their main focus is CAD CAM where a plain STL is sufficient.
Claas Kuhnen
