I am trying to use a cam template but there are so many!!!
how do I access the cam template folder on my computer so I can remove the old files! ?!?!?
the assists cloud version of cam templates is already cleared out but I cannot for the life of me find my templates folder on my pc !?!?!?
where are they ?
Can someone navigate me there ?
Solved by HughesTooling. Go to Solution.
I am pretty sure you will find them in C:\Users\<username>\AppData\Local\Fusion 360 CAM
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
Have you tried enabling the template library manager in the preview section of preferences?
It adds an option to the manage menu that calls up the manager below. You also get this same interfase when you want to create from template.
Mark
Mark Hughes
Owner, Hughes Tooling
