Cable chain
6 REPLIES 6
O.Tan
2507 Views, 6 Replies
Cable chain
Anyone has any idea how to animate cable chains? I saw some videos that it's possible with Inventor but since Fusion uses Joints, I wonder if there's any other way or do the Fusion team has something coming up regarding chains.
For those who don't know what cable chains are, they look like these.
http://www.igus.com/wpck/3512/overview_EasyChain
Omar Tan
Malaysia
Mac Pro (Late 2013) | 3.7 GHz Quad-Core Intel Xeon E5 | 12GB 1.8 GHz DDR3 ECC | Dual 2GB AMD FirePro D300
MacBook Pro 15" (Late 2016) | 2.6 GHz Quad-Core Intel Core i7 | 16GB 2.1 GHz LPDDR3 | 4GB AMD RadeonPro 460
macOS Sierra, Windows 10
6 REPLIES 6
innovatenate
in reply to: O.Tan
Have you seen this post?
http://forums.autodesk.com/t5/design-and-documentation/any-idea-what-to-do-next-from-here/m-p/548382...
I think it may help!
Nathan Chandler
Principal Specialist
innovatenate
in reply to: innovatenate
Sorry, I just noticed that it was you!
Nathan Chandler
in reply to: O.Tan
Wow, that multijoint chain you made Nathan is awesome!  I added an additional chain link at the end, and turned off opacity of the component that was jointed to the end link via a Slider joint (and added the maximum 30 degrees to the new Revolute joint).  Also turning off visibility of joints, and doing a motion study to animate it, gives decent footage that can be captured!
Cool how many joints can work together like that (Probably could even work with quite a few more, and also for any of the links that are not involved in changing angle, I would be sure to add a Slider joint for each to the bar component (that normally has opacity turned off).
https://drive.google.com/file/d/0B3hl1g1DsQouRGNSa3lKRkJZMEE/view?usp=sharing
O.Tan
Ah yes it's mine, so is there any updates on the development side? Cause I know this is one of joints limitation but not sure about others yet.
Omar Tan
Malaysia
in reply to: O.Tan
Hi, I'm just curious what limitation you're referring to with the current implementation shown (that includes chain stabilization with one or more slider joints)?
Jesse
in reply to: O.Tan
I'am trying to make cable chian and keep getting  yellow cochin mark on the left side how would i cam the oval inside wholes out i have video to help you with what iam talking about any help would be appreated
Technology Administrators
