Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
BUG: stitching
14 REPLIES 14
Message 1 of 15
cekuhnen
513 Views, 14 Replies
BUG: stitching
cekuhnen
looks like the patch tool has some issues here. Based on continuity setting Fusion can stitch or not but this is a pretty simple surface.
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
BUG: stitching
Claas Kuhnen
14 REPLIES 14
Message 2 of 15
in reply to: cekuhnen
Huh, worked fine for me (attached).  Try reloading the file, or perhaps a Mac issue? (that would be strange).
Jesse
Jesse
Message 3 of 15
cekuhnen
cekuhnen
@Anonymous
re-imported the file Fusion mac and stitch failure.
Claas Kuhnen
@Anonymous
Claas Kuhnen
Message 4 of 15
cekuhnen
cekuhnen
@Anonymous
yep also in Win7 it fails.
Claas Kuhnen
@Anonymous
Claas Kuhnen
Message 5 of 15
Whaa?  What could possibly be the difference then?  Hmm.
Message 6 of 15
When you re-imported my .f3d file, how many bodies were in it?? (mine obviously should only have one, being stitched).
Message 7 of 15
cekuhnen
cekuhnen
@Anonymous ja kinda holarious that on both OSs it fails for me but not for you
Autodesk stop remote crashing my Fusion - stop that mean spying at once :0)
I imported my Fusion file I attached to the web because that was the source file that failed
Claas Kuhnen
Claas Kuhnen
Message 8 of 15
Haha, yeah I'm sure they got a lot of extra time to kill, and thought it would be fun to mess with our minds 😉
Message 9 of 15
schneik-adsk
schneik-adsk
Try changing the tolerance to .333 mm
Kevin Schneider
Kevin Schneider
Message 10 of 15
Alright I deleted the two stitch operations and just consolidated it to one stitch operation.  It also for some reason needed the tolerance increased to stitch everything together (appears must be a tiny gap somewhere perhaps from the way it was created? hmm).  Hopefully now it will work with no funny business.
Jesse
Jesse
Message 11 of 15
in reply to: schneik-adsk
When in doubt, .333 will clear it out 😉
Message 12 of 15
cekuhnen
cekuhnen
But why this should not be an issue to use that tolerances for st that make a bad seam.that could be actually open?
Claas Kuhnen
Claas Kuhnen
Message 13 of 15
schneik-adsk
schneik-adsk
it will be fine.
Kevin Schneider
it will be fine.
Kevin Schneider
Message 14 of 15
It does not appear in this case that there actually was any gap, but by changing the tolerance, it appeared to reset some issue (I was seeing a little bit of strangeness too, after which was able to go back and return the tolerance back to zero even).
Jesse
Jesse
Message 15 of 15
cekuhnen
cekuhnen
Yeah no gaps checked it in Alias.
The tangent and smooth are not hitting their requirement when checking for G1 and G2 continuity.
Claas Kuhnen
Claas Kuhnen
