[BUG] Spline dimensioning flips handle etc.
TrippyLighting
Consultant Consultant
TrippyLighting
Screencast is self explanatory. I cannot fully dimension this simple T-Spline without spending considerable time using a workaround.
Again, I find a bug helping another user with a very simple design!
Edit: This gets even better. I though I had a workaround. To be able to dimension the hands I though I just draw a horizontal line constrained to the handle on one end and the center line on the other. But instead of providing me with two profile selections, it kills the profile:
jeff_strater
Thanks Peter. That certainly is a bug. I'll pass it on to the sketch team. I've seen problems dimensioning the handles, but usually the fit points work well.
Jeff
Jeff Strater
Engineering Director
TrippyLighting
Another thing that I found was that when I am dimensioning something but decide I want to cancel the command and hit the escape key to do so, the command is actually completes and the dimensioning is applied rather than cancelled. Is that expected behavior ?
SaeedHamza
Hi Peter,
This is indeed a strange issue, the stranger is that I didn't have such issue when I tried what you did
Here is a screencast of me doing it, did I do something different from what you did or is it the same?
Kind Regards
Saeed
Saeed Hamza
jeff_strater
@TrippyLighting:  Regarding ESC and Dimension, do you have the "Edit Dimension When Created" option turned on?  If so, then I suspect what you might be seeing is that ESC cancels the edit operation, not the dimension operation.  However, I just tried that, and ESC with this option on doesn't even cancel the edit.  So, I'm not sure what that one is.
Jeff Strater
