Bug Report :Section Analysis
2 REPLIES 2
Patan77xD
285 Views, 2 Replies
Just reporting a bug that I noticed, I have created a custom thread as a separate body then I join it to the main body, however when I do section analysis it create some strange graphical artifacts, there is no gap between the the thread and model because I have made sure the thread have some overlap, the graphical  artifacts is visible in both perspective and orthographic view but the model looks correct so don't think it an issue with the model.
Tags (1)
2 REPLIES 2
TrippyLighting
in reply to: Patan77xD
This isn't necessarily a bug. Can you change the display detail control to   fixed/high?
You need to select the component/body and right-click and find the Display detail control in the menu.
Patan77xD
in reply to: TrippyLighting
Yes, changing it to fixed removed the graphical artifacts even at low settings, however it still technically a bug/graphical artifact when in adaptive mode, and they should fix if they can.
Technology Administrators
