BUG: Parameters turning to shortcuts
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have been using Fusion for a year or so now and this is the first time I have noticed this problem.
I made two user parameters: 'AA' the diameter of a circle = 33.3mm. 't' the thickness of cylinder I want to make = 3.6mm.
When I sketch a circle and type AA in the dimension, it works fine and I get a 30mm diameter circle. When I sketch a second circle and try to type AA+t in the dimension, the trim shortcut opens and I lose the dimension. If I type t+AA in the dimension, then I get a circle with a diameter of 36.9mm as expected.
I am using the latest version: 2.0.2539
I can use the work around, but I see this being a problem if I start making more parameters that open their shortcuts when I try to enter them into a dimension text box.
Matthew
