Bug in text editor
Bug in text editor
fkKNLVL
Bug in text editor
fkKNLVL
I can't write text in the text editor, only some letters and if they show up they show up with number "1" infront of them.
Like i cannot write a small x but i can write m but it shows up as "1 m"
Here is another example: a small f becomes "1 F"
Seems like something is wrong with this text editor. 🙂
I'm using the latest build
Fusion 2604.0.316 x86_64
jhackney1972
You are experiencing the new Parametric Text function but are not understanding how to enter your text.  With Parametric Text you must inter regular text between the two apostrophes.  Look very close when you start the text command and you will see these apostrophes.  If you start typing, your text should start after the first apostrophe and you will need to be sure your text ends in an apostrophe.  Below is the text editor with these apostrophes indicated.  I suggest you read the What's New Blog about the latest Fusion update.  Here is the link, once open scroll to the section on parametric text.
If this answers your question, please select the "Accept Solution" on my post. If you need further help, please ask.
John Hackney, Retired
