BUG? Can't Move files and folders up in the Fusion Tree in Browser
Message 1 of 13
Today - 4th April 2020 I tried to move some folders around using the Fusion 360 Browswer file viewer.
When you select move, you can only see the folder level that you are at and not up the tree so you can't move things up to a higher folder level. This also happened a few days ago. I am now stuck with not being able to rearrange folders as you can't seem to move folders from within Fusion these days.
Replies (12)
Message 2 of 13
HughesTooling
What I see is all folders at the top level in the project, so you need to select the folder your subfolder are in then the subfolders from there. Not the best solution but you should be able to at least move the designs for now.
Below the file I'm trying to move is in a subfolder of Boundary fill test, if I double click the "Boundary fill test" folder I'm taken to that level then can select its subfolders.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 3 of 13
sasikanth.kollipara
Thanks for posting.
If I understood the problem correctly, that you are trying to move the file from "test level" folder to "Boundary fill test", if so when you click on the move button you should be able to see the list of folders.  Instead of double-tap, do single tap on the folder and then click move do not double-tap as it goes inside the folder.
Hope this helps.
sasi
Sasikanth Kollipara
Product owner and customer support in Fusion
LinkedIn
Message 4 of 13
Hi Mark
Thanks for the reply, but I think we are talking about different things.
The move you seem to be making is within the Fusion 360 Program - but in the Fusion 360 program I can't work out how to move folders so need to move to the Fusion Browser by clicking on this button.
It is in the Browser file manager I am having the issue moving.
Please see the video
Julian
Message 5 of 13
HughesTooling
Think I came across this problem myself yesterday. What I found is you need to click on the triangles but the hotspot you need to hit is quite small, you need to hit the very centre of the triangle.
Mark
Mark Hughes
Message 6 of 13
sasikanth.kollipara
 i hope this problem is solved, please let us know if this can be closed.
Sasi
Sasikanth Kollipara
LinkedIn
Message 7 of 13
Hi Mark
Hmm - that isn't the issue. I know what the triangles do - but they only take you down the tree not up it.
What I want to do is go to the next level up.
Perhaps to see if you have the same issue can you open the folder "Boundary Fill Test " in Fusion 360 then click through to the the Fusion File Web Browser and see if you can get back up to TEMP.
Julian
Message 8 of 13
HughesTooling
OK think I see it now. @jeff_strater  Not sure who to tag for this. Below you can see I'm in folder TestLevel but when I try to move or copy there's no way to get back to the top containing project Temp to copy to any of its other folders. I can go up one level to Boundary fill test but that's it.
Thanks Mark
Mark Hughes
Message 9 of 13
That's the one Mark - given you can replicate it - it looks like a BUG that needs fixing.
Message 10 of 13
GRSnyder
@HughesTooling, how are you able to move folders at all? Right-clicking on a folder gives me only the options Rename, Delete, and Add to Offline Cache.
Message 11 of 13
Just tried this again today and seems to work so I think this is resolved now - Thanks Fusion Team
Message 12 of 13
mrholden
Community Visitor
Community Visitor
Not a great solution, but open up fusion in a web browser and do all the file moving there. The bug was not on the browser but was on my local application. My local files updated to reflect the changes I made on the web almost immediately.
I know the post is old so this is mostly for my own future reference haha. Hope it helps someone.
Message 13 of 13
grad2
All I get when I try to move things in the file browser is 'could not move selected folder'
