Bug adding a parameter as a dimension.
HughesTooling
Consultant Consultant
HughesTooling
If you try using a parameter in the dimensions while drawing a rectangle only the size is entered into the dimension.
Screencast.
Mark
Mark Hughes
Owner, Hughes Tooling
jeff_strater
Thanks for the post.  This is a known issue (FUS-20564), and we do hope to have a fix for it before too long.  The workaround, of course, is to use the parameter dialog, but that's obviously not ideal.
Jeff Strater (Fusion development)
Jeff Strater
Engineering Director
This bug affects all figures except the circle  - http://forums.autodesk.com/t5/design-validate-document/help-parametric-modeling/td-p/5928080
Previously, everything worked as it should
daniel_lyall
@jeff_strater there is a way around it you ever click in the demented box so it high lights and if the user demean name poop's up just hit enter and it's fine, if that does not work doing the same thing to the user parameter work's as well, if you start with a circle it is going to happen, if not it's random.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
