Help parametric modeling
Message 1 of 9
Help me understand why not apply some of the parameters when drawing figures. I point out the name of the parameter when making a circle - it is marked with the "FX" if it works and to change, but when you create a rectangle parameter is converted to a resolution. And its size does not change when I change the appropriate option.
Replies (8)
Message 2 of 9
daniel_lyall
this is a bug I have just run into it my self when you set the user paramiter if it does not show up with the fx double click on the parameter box and hit enter.
I will see if I can do a screen cast for ya
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Message 3 of 9
daniel_lyall
I cant reproduce this bug in a new sketch it's a random bug
Daniel Lyall
The Big Boss
Mach3 User
Message 4 of 9
Message 5 of 9
daniel_lyall
just did the screen cast it is how I said to fix it highlight (not double click my bad) the demention and hit enter took time to get it to happen again
Daniel Lyall
The Big Boss
Mach3 User
Message 6 of 9
daniel_lyall
@brianrepp    he is a bug for ya it does not happen everytime.
@Anonymous here is the screncast         http://autode.sk/1MX38CM
Daniel Lyall
The Big Boss
Mach3 User
Message 7 of 9
jeff_strater
Thanks, @daniel_lyall.  That screencast is very helpful.  It is, indeed, the same basic bug as in bug-adding-a-parameter-as-a-dimension.
I hadn't before, though, realized the "randomness" of this bug.  Very strange, software does not tend to be that random....
Jeff Strater (Fusion development)
Jeff Strater
Engineering Director
Message 8 of 9
daniel_lyall
@jeff_strater I hit it a couple of time when I was makeing adjustments to a sketch,  it did not happen on every demention just some, I just had to highlight the box and it pooped up with the user demention and I hit enter and it was fine.
Daniel Lyall
The Big Boss
Mach3 User
Message 9 of 9
daniel_lyall
@jeff_strater here is another example, any eta on a fix its a bit off a pain
https://www.youtube.com/watch?v=I0S_ExpZSZU
Daniel Lyall
The Big Boss
Mach3 User
