boundary fill does not create solid - why?
cekuhnen
Mentor Mentor
Message 1 of 15
cekuhnen
I need to add a stitch command to make it solid ... but why?
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
Replies (14)
Message 2 of 15
jakefowler
Hi @cekuhnen
Are you able to share the design?
Boundary Fill works best when surfaces have a bit of overlap. Sometimes it can encounter problems with surfaces that are 'just touching', whereas Stitch will take care of just-touching conditions by connecting any edges that meet within your specified tolerance.
Jake
Jake Fowler
Principal Experience Designer
Fusion 360
Message 3 of 15
cekuhnen
@jakefowler The boundary fill is done by using two surfaces that are overbuild well - so overlapping a lot.
That is why I am curious why this does not make a solid when it is a closed shell.
Claas Kuhnen
Message 4 of 15
jakefowler
@cekuhnen
This should be working fine then - sounds like an unexpected error. If you're able to share the F3D, we can certainly take a look into this.
Many thanks,
Jake
Jake Fowler
Fusion 360
Message 5 of 15
cekuhnen
@jakefowler
Here it is: http://a360.co/2b5WTUk
Let me know what you found out!
Claas Kuhnen
Message 6 of 15
jakefowler
Thanks for the file! I can see the issue. We are technically making a clean solid, but the browser doesn't seem to reflect that. If I roll back to the Boundary Fill feature, Edit it, and click OK, it shows up as a solid. But then moving the timeline marker again reverts it to a 'surface' in the browser. So there's definitely something fishy going on - we'll look into this one.
Much appreciated,
Jake
Jake Fowler
Fusion 360
Message 7 of 15
cekuhnen
@jakefowler No problem.
Claas Kuhnen
Message 8 of 15
HughesTooling
@cekuhnen I downloaded your file to see how you were using the Remove feature. If I try and edit the loft I get an error and if I just open the file and run Compute All the loft gives an error, am I missing something or is there a problem in the file.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 9 of 15
cekuhnen
@HughesTooling The loft code is not really good.
Oddly my file checks fine also in the loft command I don't get the error
Claas Kuhnen
Message 10 of 15
HughesTooling
In the file I downloaded the tangency weight for both profiles was set to 2.5, setting the 2nd profile to zero cleared the error, anything but zero for the second profile seems to fail.
Anyway here's an edited version without the unstitch or the removes, I just used Delete in the patch workspace. Is it any different to what you where after?
Mark
Mark Hughes
Message 11 of 15
cekuhnen
@HughesTooling Odd - why do you have Loft tool issues and I do not ?!?!?!
Claas Kuhnen
Message 12 of 15
HughesTooling
Mac PC perhaps, I think you use a mac?
Mark
Mark Hughes
Message 13 of 15
kb9ydn
So here's something weird, the hotkey for compute all (ctrl+B) doesn't work.  But if I select it from the menu it works and flags the loft with an error.
I'm on a PC with Windoes 10 if it matters.
C|
Message 14 of 15
cekuhnen
This is bizarre!
Claas Kuhnen
Message 15 of 15
HughesTooling
@cekuhnen Here's the file I downloaded, does running compute all give you any problems using this file. I wonder if the download\translation is the problem.
Mark
Mark Hughes
