Body copy with independent parameters
dr.kaban
Message 1 of 8
dr.kaban
Hi, I am trying to create a copy of the original body that would be possible to change the parameters independently from original body.
Here I have two coils on the cylinder. One is original, another is a copy of it. For one of them I would like to change pitch, diameter, section size, etc. But whenever I change it, both bodies change.
How can I get just one of them modified?
Thanks, and sorry if the question is answered somewhere - could not find it 😞
Replies (7)
Message 2 of 8
Marco.Takx
Hi @dr.kaban,
The best way to have individual parameters after copying the body is to do that on a component level.
So create a component and copy and Past New the component into the browser.
Now you have new parameters for that specific component
If my post answers your question Please use Accept as Solution & Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
Message 3 of 8
dr.kaban
tried it, thanks
can't get it working anyway
after i try to change one component's body, the other does the same. though i pasted is as "new" 😞
would you try seeing what is the problem?
here's the link
i am about to change one of the two coils on the cylinder - namely, change the diameter from 26.445 to 24.265 for one of them.
I am curious if you mange that...
https://a360.co/3b6otw3
Message 4 of 8
LeonardoBN
Hi @dr.kaban. I tried to replicate your model, and I create the first coil in a new component. So I could Copy/Paste New. Then you will have a file structure like @Marco.Takx pointed out above.
Your Parameters list should then have this appearance:
See the attached F3D file.
Leonardo Brunelli do Nascimento
Chemical Engineer
Message 5 of 8
dr.kaban
I'm trying to do the same (copying a component and pasting as new), but instead of independent new "coil primitive" i am getting "move"
what i am doing wrong???
Message 6 of 8
jeff_strater
paste (or paste new) will do the paste, then immediately put you into Move so you can re-position the new component.  Move it and you will see.
One important note here:  If you cancel the Move, you still have done the Paste!  There will still be a new component in your model (check the browser).  You will have to undo the Paste to get rid of it.
Jeff Strater
Engineering Director
Message 7 of 8
LeonardoBN
Based on this image, I will suppose your F3D file remains the same.
You created a Coil, then created a component from this solid:
If you change this order, creating firstly New Component, which is always a nice practice, and then working in your first coil, you will get what you want.
Then you can Copy/Paste New this Coil component, and you will have two set of parameters.
I used this approach in the last file I attached here.
Chemical Engineer
Message 8 of 8
dr.kaban
thanks, it worked ))
