Best way to put a gear teeth in a curve.
Message 1 of 12
What's the bColumn base 001.jpgest way to put a gear teeth in a curve.
Replies (11)
Message 2 of 12
chrisplyler
With something sharp.
Message 3 of 12
etfrench
While @chrisplyler's answer is mostly correct (a dull cutter will also cut the teeth), you may want some additional information.
Use the spur gear script on the Add-Ins menu.  Make the gear 360 degrees, then cut the unneeded area.
ETFrench
Message 4 of 12
TheCADWhisperer
Make full circle gear.
Cut off excess.
Message 5 of 12
chrisplyler
Up to a point, sure. But it isn't the BEST way, which is what was asked for.
Message 6 of 12
TheCADWhisperer
Maybe the Design Intent is 3D print of the part?  Smiley Wink
Message 7 of 12
sanket223.patil
In sketch create circle and pattern the teeth in circular pattern and after cut of extra . If you already have that shape but no teeth then create sketch of teeth and pattern the feature along the path .
Sanket Patil
Mechanical Engineering
Expert Elite
Message 8 of 12
TheCADWhisperer
@sanket223.patil wrote:
... pattern the feature along the path .
Looks like a simple Circular Pattern to me?
Message 9 of 12
How would I cut of the access? And how do I match the gear size of the smaller gear?
Message 10 of 12
etfrench
You'll need to know the module number if metric or the diametrical pitch if imperial of the gears. You'll also need to know the center to center distance between the gears.  The number of teeth (plus the module/diametrical pitch) of each gear will give you the pitch diameter of the gear.  The pitch diameters of the gears must be tangent, so this determines the center to center distance.
Once you know that, you can create the gears.
Extrude|Cut is one of the basic operations in Fusion 360.  You should go through the Learning topics located at the top of the forum.
ETFrench
Message 11 of 12
chrisplyler
Wait... is this a "How do I model it in Fusion 360 question?" Or is this a , "How do I go to Mechanical Engineering school and learn how to design gear teeth" question?
Message 12 of 12
It's the forget I even asked a question!
