Best way to model this simple bracket? Beginner question
Message 1 of 15
Hello! I come from Cinema 4D and now getting started with Fusion 360 to get more precise in my models.
I would like to know which is the best way to model a bracket like the one in the picture, with the ability to change dimensions and angles whenever I wish:
The way I approached this model:
1 - I drew lines of each face in the right view
2 - Applied Extrude from the Surface menu.
The problem with this approach is that I cannot give dimensions on the front view, which I am only able to see after I apply the Extrude command. I would like to, for example, make the top face edge narrower, as it is in the technical drawing below:
To better illustrate what I need to achieve, here is another image:
Another way I tried to tackle this model was by drawing everything in a single skech in the front view. The problem then, was that I do not know how I could rotate the faces to specific angles:
Another approach. Drawing everything in the front view. I used a single sketch.Another approach. Drawing everything in the front view. I used a single sketch.
If you had to model this object, how would you do it? Draw in the front or side view? Another way?
I would like some guidance on what would be the steps, like 'draw in the front view, then extrude, then add thickness...".
Thank you very much!
Replies (14)
Message 2 of 15
TheCADWhisperer
Trim surface and Thicken.
or
Flange
Unfold
Extrude
Refold
Back in a few minutes.
Edit: Is this a school assignment?  Do you have a technical drawing showing the dimensions of the part in folded form?
What is the thickness of the material?
Message 3 of 15
MRWakefield
I'd use the Sheet Metal workspace for this. You can create it in the flattened state as per your drawing then add the bends.
If this answers your question please mark the thread as solved as it can help others find solutions in the future.
Marcus Wakefield
____________________________________________________________________________________
I've created a Windows application (and now Mac as well) for creating custom thread files for Fusion. You can find out about it here. Hope you find it useful.
If you need to know how to offset threads for 3D printing then I've created a guide here which you might find useful.
If you would like to send me a tip for any help I've provided or for any of my software applications you've found useful, you can do this via my Ko-Fi page here.
Message 4 of 15
Wow wow! Exactly what I want to model.
I'm trying out to help the engineers of my work with some 3d modeling, although it's not my area (I am a graphic designer).
Thanks a lot for your time showing me this. I will study the file to see how you achieved it and try to do one myself. I might bother you again asking how you did something I couldn't replicate, I hope that's fine 🙂
Message 5 of 15
TheCADWhisperer
...and the finished part Attached.
Message 6 of 15
Quick question: how do you set the thickness after you add the Flange?
Thanks once again!
Message 7 of 15
TheCADWhisperer
Edit RuleEdit Rule
Message 8 of 15
Thanks again! I am getting close to the model. you created.
I came into a problem:
The way I draw it using the front view wasn't centered, meaning that any action with symmetry it's useless. I would like to achieve the same end result of the drawing you have in your file (it is centered).
Is there a way to center all my first drawing? I've seen tutorials showing how to center but they are always using a single draw as an example. I will need to move everything.
Message 9 of 15
MRWakefield
If you can upload your file or a link to it we'll take a look.
Marcus Wakefield
Message 10 of 15
Thanks for considering it.
I could achieve a final result as I wanted. Of course it would be better if I could center the drawing to make the circle wholes with symmetry. I have attached my file.
Message 11 of 15
TheCADWhisperer
Your Sketch1 is not fully defined and you have wayyyyyyyy too many dimensions.
Establish a Construction line for symmetry and use Symmetry constraints.
Message 12 of 15
I put all dimensions on Sketch1 in order to be a single place if I need to change anything in the base sketch.
Is it a bad practice?
and what do you mean with not fully defined?
Message 13 of 15
TheCADWhisperer
Examine my Sketch1.
Note all dimensions needed for the model.
Note all geometry is black (no blue geometry).
Note Lock symbol on Sketch1 in browser.
Note duplicated dimensions removed.
Message 14 of 15
TheCADWhisperer
Examine the Attached file and now apply a Coincident constraint in Sketch1 between the Origin and the central point.
Message 15 of 15
I was able to set it to the center after following your instructions. Your Sketch as lots of Construction lines, which were not in mine.  I guess I need to study a lot more about using Constraints as well.
Do you have any tutorials to recommend regarding Constraints and Construction lines that I could watch?
Once again thank you a lot for your time helping me out.
