- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm working on a simple design of a table saw. It's a mock up of a real table saw I want to build a cart for.
I was curious what the best practices are for re-using sketches that could be used to cut extrude an opening into a body and also to create a new body that would eventually be a new component to fill the original cut extrusion. Consider the case of a table saw top that has a plate on the surface for the saw blade. Both the blade opening on the table surface and the plate that fill it share the same profile dimensions. Can you use the same sketch for both or do you have to duplicate it? What's the best way to handle this?
-Freeman
