Bend lines inserted into drawings
timothy.erickson
Message 1 of 8
timothy.erickson
Hi, I am curious if anyone else out there is running into this same issue. I am trying to insert press brake bend lines into my prints in the drawing portion of Fusion 360. Any answer will help. Thanks
Replies (7)
Message 2 of 8
luciacasu
Hi Timothy,
sorry you're having issues with drawings in Fusion 360.
Can you describe your workflow?
Also an image of your Fusion drawing would be useful to understand more about your problem.
Lucia Casu
Fusion360 Development
Message 3 of 8
timothy.erickson
I would like to represent a bend line setup for a pressbrake. The attached pdf is an example of a flat shape and a formed shape. I would like to put a bend line into the flat shape to show where you have to set the pressbrake up to bend the part.
Message 4 of 8
TimeraAutodesk
Hi @timothy.erickson - you need to create a flat pattern of your sheetmetal component first, and then you can insert the flat pattern (with bend lines included) into your Drawing.
Message 5 of 8
pyramid.adam
What type of line signifies a 'bend line'? I can't work this out.
Message 6 of 8
g-andresen
here is the process:
and here the bend lines in drawing mode
bend lines in drawingbend lines in drawing
günther
Message 7 of 8
JDMather
Share your project if you can't figure it out.
Message 8 of 8
serviceHT2YG
Community Visitor
Community Visitor
Create Drawing and choose 'Selection' instead of 'All'.
Select the Flat Pattern you want to make the Drawing of
After you insert your desired Base View, expand that part in the Browser Tree
Turn On Sketches.
Doing this displayed Bend Lines generated by the Flat Pattern.
@JDMather Doesn't directly answer your Line Type question but rather the Thread question (I'm curious about Line Type as well)
