Consolidating imported faces?
Message 1 of 15
I imported a file from Solidworks as a DXF to do text around a curve.  The faces once I extruded them are many many small simple faces.  I am trying to draft them so I can make a proper mold.  Is it possible to consolidate them so I can do fewer clicks to draft? Or am I stuck clicking a ton of times.?
http://a360.co/2gXWdVw
PS, its just a name of a camping trip.
Replies (14)
Message 2 of 15
SaeedHamza
Merging the faces in the sculpt environment is the only way to connects them, and using the chain selection can be helpful
Regards
Saeed
Saeed Hamza
Message 3 of 15
how do you chain select? I keep trying to do that. but  not sure if I am doing it right?
Message 4 of 15
SaeedHamza
The main problem is caused by your sketch, you see when you imported this dxf into Fusion, it became multiple lines
Here is a screenshot to show you what I mean :
Saeed Hamza
Message 5 of 15
What command do I do to patch it?  Not sure about that function.  Never done that type of operation before
Message 6 of 15
SaeedHamza
Here is a screenshot of the Merge command in the patch environment :
And another way to do it is by sketching over this dxf file in Fusion, Here is a screenshot of the result after I sketched over some letters ( file is attached ) :
Kind regards
Saeed
Saeed Hamza
Message 7 of 15
are you running Fusion Ultimate?  I apaprently don't have the merge option? unless I need to activate it in a menu?
Message 8 of 15
SaeedHamza
No this is normal Fusion, but you should do the extrusion and have the faces for the command to appear
Saeed Hamza
Message 9 of 15
weird.  It will not come up for me.
Message 10 of 15
never mind, i figured it out. me being blind as a bat sorry
Message 11 of 15
ok, i get the command now. however when ever i try to select the whole series of faces it errors out.  if i select anything else and hit merge. it crafts it into a weird body shape?  What am I doing wrong lol
Message 12 of 15
SaeedHamza
Could you please show a screenshot or perhaps a screencast of what you have?
Saeed
Saeed Hamza
Message 13 of 15
Message 14 of 15
Sorry for the lag in the middle. my computer does not like what I am doing.
Message 15 of 15
SaeedHamza
This is exactly the problem, you should select them face by face to merge them, and not a window selection, although usually chain selection helps a lot, it's doesn't help in your case
That why instead of taking too long to select the faces, just sketch new letters on the dxf ones
Use the text command in the sketch menu to create new letters of the same fonts, and place them on the dxf ones
Regards
Saeed
Saeed Hamza
