- Mute
- Permalink
- Report
I'm struggling with how to align basic shapes. The only way I can do it is to draw a set of construction lines and create a point at the center where they intersect and to do a move to the center line of each.
For example, consider to rectangles. I would like the smaller of the two rectangles to be moved to the center of the large rectangle. Short of drawing construction lines, how could I do this?
In the same area, say I had a bunch of squares.
How could I align these to the top of the highest square? Also, how could I horizontally distribute them so that their midpoints are an equal distance apart? My current approach would be to make construction lines and to do the math of exactly where they should be. The other option would be to do the sketch in Visio and import it.
I'm new, but this desire has come up repeatedly in my first several projects. Thank you very much for any help.
Tim
