barrel / cylinder cam
treasurhuntr
Message 1 of 16
treasurhuntr
Hi, I'm trying to make a barrel cam. Can anyone help me with this please!!?? Thank you.....
Replies (15)
Message 2 of 16
TrippyLighting
Sure! Can you share the model you've got so far ?
Message 3 of 16
TheCADWhisperer
The same question has come up here 3 times in the past week.
Is this a class assignment?
Do you have any reference material for the specifications (like a textbook page)?
Message 4 of 16
treasurhuntr
Hi, no it for a project I am currently working on. The Cylinder Cam is for
a revolving cam actuator that needs to be guided. Its for a prototype low
rpm high torque electrical turbine. Your help would be greatly
appreciated. Lou
Message 5 of 16
treasurhuntr
appreciated. Lou
Message 6 of 16
treasurhuntr
HI, yes. that would be ok with me. How would I go about doing this? Cheers,
Lou
Message 7 of 16
treasurhuntr
Lou
Message 8 of 16
TheCADWhisperer
File>Export to your local drive and then Attach to a Reply here.
Message 9 of 16
treasurhuntr
Thank you for your willingness to help. Here is the Turbine as it is so far.....Lou
Message 10 of 16
TrippyLighting
I posted a solution of how to create a barrel cam in this thread.
Message 11 of 16
treasurhuntr
awesome!! thank you!
Message 12 of 16
treasurhuntr
Message 13 of 16
TrippyLighting
@michallach81posted an improvement with the correct geometry in this thread.
Message 14 of 16
swaterman9LM53
Hello, I'm a bit hung up on creating a barrel cam as I am new to this.  I have drawn what you have for the barrel cam, but not sure how to connect all the dots using spline. How are you using spline to connect to each point on all plane levels?
Message 15 of 16
TrippyLighting
Here is the screencast I created in one of the barrel cam threads. Be aware though that this does not create entirely correct geometry. it was pointed out and corrected in one of the other threads that are linked to in this thread (I believe)
Message 16 of 16
swaterman9LM53
I did just like your video showed and I got it to work just fine.  One thing I didn't have clicked in the sketch palette was the 3D Sketch.  My boss thought that was a pretty clever way of doing a cam and will apply that principle towards other applications.
Thank you, that was a big help!!
