Bad DXF export
Bad DXF export
hato54
Bad DXF export
hato54
I like to export this (drawing) in dxf format:
But when I upload and open it will be like this:
I have also imported the file in SolidWorks, same bad dxf.
hato54
I restarted Fusion 360 and made a new export then it works, STRANGE!
Mike.Grau
Hi @hato54,
Thank you for sharing this.
I will look into this issue and share more information within the team.
We will keep you updated.
Tom73787
Hi Mike,
I experienced the same issue and found this page after searching on Google for "Bad DXF export". I restarted Fusion 360 as instructed and I got the correct .DXF
Tom
ymif1
Same problem, same solution! THANKS Hato54!
I've had this a few times before, but i didn't know how to fix it. So it is nice to know how to do this now, but this shouldn't be the way of working.
Question to Mike or somebody else from the fusion team: is this bug known? And is it fixable?
Best regards,
Ruud
