Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Axis through cylinder is off in space
11 REPLIES 11
Message 1 of 12
ELAFING
570 Views, 11 Replies
Capture-axis through cylinder.JPGI selected the inside face of a bearing block and the axis line is way way off. Any ideas?
11 REPLIES 11
Message 2 of 12
jeff_strater
in reply to: ELAFING
I suspect the axis is correctly aligned with the cylinder, but its "extents" are drawn incorrectly.  You can drag the endpoints of the axis to fix it.  Also, if you could share the model here, we can take a look at why the extents were drawn incorrectly.  Thanks.
Jeff Strater
Engineering Director
Message 3 of 12
laughingcreek
the endpoints of the axis can be grabbed in order to lengthen or  re-position the axis
Message 4 of 12
ELAFING
in reply to: laughingcreek
The axis line is over 70 inches away, are you saying the only way to solve this is to find that line in space and drag it back to the cylinder it is meant for?
Message 5 of 12
HughesTooling
Only seen this problem with imported parts or components that have been translated. Probably should have supplied example designs so autodesk can tune it up but always too busy at the time.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 6 of 12
TheCADWhisperer
@ELAFING wrote:
... are you saying the only way to solve this....
File>Export and then Attach your *.f3d file here and end all doubt.
Message 7 of 12
ELAFING
Here is the file.
Message 8 of 12
HughesTooling
If you export to an iges file then reimport the problem's gone. Seem to remember when I've seen this the original file (STP, sldprt) contained a block that had been translated (Moved\Rotated) and this transformation confused Fusion. Attached file is of the reimported iges file.
Mark
Mark Hughes
Message 9 of 12
jeff_strater
thanks for sharing the model.  I've created bug FUS-58648 for this.
As for fixing the result, really, it's not that bad.  Ten seconds of dragging or less is all that's needed.  Once you've fixed it, it will remain in place.
screencast:  https://knowledge.autodesk.com/community/screencast/01aaa4a1-a705-4d97-bf4f-997f6d2af99a
Jeff Strater
Message 10 of 12
ELAFING
in reply to: HughesTooling
This component is used in an assy will this break the link and the joints already applied?
Message 11 of 12
jeff_strater
in reply to: jeff_strater
screencast embedding, take 2:
01aaa4a1-a705-4d97-bf4f-997f6d2af99a,640,620
Jeff Strater
Message 12 of 12
jeff_strater
take 3
Jeff Strater
