AV in drawing while adding chained dimension
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Adding a chained dimension resulted in an Access Violation: CER_120177654
Prior to the AV, I was experimenting with dimensions to see how to get the best placement. Dimensions were created and deleted on the same object several times.
Fusion 360 Drawings Error Aborting
FATAL ERROR: Unhandled Access Violation Reading 0x00d8 Exception at bbe05056h
Ok
Clicking on 'OK' opens the following dialog:
Fusion 360 Drawings Alert
Fusion 360 Drawings cannot continue. You can attempt to save changes
into the following file up to the start of the last command:
Drawing1_recover.dwg
After you save your changes, you can open or recover the file.
Should Fusion 360 Drawings try to save your changes?
Yes No
Clicking 'Yes' opens the following:
Fusion 360 Drawings Error-abort
Error handler re-entered. Exiting now.
Ok
End result is a blank drawing with Fusion 360 still running.
ETFrench
