Thanks for the link to the road map. It is not clear to me from that if this component-non-auto-drawing issue will be addressed in 2021. After a few tests it now looks like Fusion is only capable of auto generating multi drawing sheets for anything that is an assembly, but not any non-assembly components. If Contents is set to = "Full Assembly" and Structure = "All levels" is selected it will create drawings for all Assys that go deep into the structure it seems. But it will not do the final components. That "Full Assembly and All levels" choice now appears misleading. In contrast, if Structure is set to = "First level" then it seems to create drawings for only the first Assembly level below the top assembly level and that outcome aligns with the choice as described.
This is a major problem, at least for me, that I need to resolve soon. Is there a way to find out the best work arounds being used by others? One dodgy workaround I can think of could be to just trick Fusion into drawing components by making every component into an assembly; for example, by attaching some small inconsequential component below each component, perhaps an empty component? But this could backfire when trying to handle BOM's, creating more work and mess. I am not game to experiment with that, but maybe someone else already has and can advise.
Another related topic I noticed in the road map under title block was "Auto populate more attributes". This is a related concern I also recently discovered while attempting to create drawings. Of particular concern is the component description not coming from the browser into the title block - so in effect every sheet in the drawing ends up with the same title, ie. the main Assy (Title 1). Improving this attribute transfer seems to be much more important than transferring physical material or weight, but it is not clear if component descriptions will be made to come into title blocks. Is this being addressed in 2021 too?
Also for me it is confusing to refer to the non-transferable information as "attributes" or "custom attributes". To me that information is just "fields" or even just "place holders" within a drawing, not attributes of the model.
